330 ATP dash panel out
Old Feb 18, 2013 | 03:16 AM
ErnieATV330's Avatar
Default 330 ATP dash panel out
I'm a new AtV owner and not very mechanical. I recently had my 330 ATP tuned up and shortly after getting it back I noticed I had to charged/jump the battery more often than usual. The other day it died out on the street and had to jump it with my car then I noticed the dash panel went out completely and I haven't been able to get it back on. Did I blow something out because I jumped it with my car? Please help. Thanks
Old Feb 18, 2013 | 07:11 AM
What year model on the Atp 330? If it's a 2005 model it's possible that you could have shorted out the ecm module. Same thing for the earlier models,but bulbs take the brunt of any electrical spike, usually before it hits the major electrical components. There is a 20 amp circuit breaker in a sealed pouch on the 2004 model,not on the 2005 (I believe) you might check to see if it's been damaged and has power to each side. If the engine cranks up with the electric start then the fuse is ok. Please don't double post in this section and in the normal thread area on the same topic!
Old Feb 18, 2013 | 07:37 AM
It's a 2004. The lights in high work but not in low position. I also have a winch on it that works too. It also doesn't turn on at all. No click or anything. Thanks
Old Feb 18, 2013 | 07:43 AM
On something like this you have to start with a good battery and troubleshoot the wiring,connections and modules. I've had this happen many times on machines jumped off from car/truck batteries.
Jeff Roper
Feb 1, 2022 11:48 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
salixair
Nov 3, 2015 08:25 AM
mywifesquad
8
Sep 21, 2015 08:20 AM
400H0
10
Aug 20, 2015 07:34 PM
