CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
2006 Ds 650 help me please
Old Feb 22, 2013 | 06:55 PM
pplblazerdude's Avatar
Default 2006 Ds 650 help me please
I have recently traded for a DS 650 2006 model and the bike is in pretty good shape. When I got it seemed to run good and after riding it some more I noticed it would die after very hard acceleration. I pulled the carb and cleaned it out and everything seemed to be good. Still could not get it to run good. Checked the gas tank vents and they are open and good. Has a new set of fresh ngk plugs in it. I have set the idle and pilot screw via the omr carb tuning advice.
The bike still does not run right. It will pull good till you rail its guts then it will cut out and not rev. If you slowly get into the throttle I can get it to rev to almost 7k but if you rap the throttle fast you are lucky to get to 5k. The carb has the stock jet in it. When I got the bike the pipe was gutted. I repacked the pipe. All the bike has done to it is a uni style filter.
I am at the point of throwing a larger jet in it to see what it will do.
Any advice or direction to go with it. This bike has me so fired up as I know it will scream and I am ready to ride.
PS the plugs are a very very very light shade of brown. I believe its running lean per my idea of going to a larger jet.
Thanks for your advice in advance.
Old Feb 26, 2013 | 04:55 PM
justme23005's Avatar
Have you checked to make sure you have a good supply of fuel to the carburetor?
Old Mar 1, 2013 | 11:31 PM
O2x4's Avatar
Default One day
I got mud down tbe carb vents once. It ran like crap. Alot like you describe. Had to drench every tube and jet n hole n blew everything out backwards with a compressor. Maybe you missed a cunk o mud in a lil tube thats drilled through the carb.
ltrmc02
Aug 22, 2021 02:34 PM
akguy31
Aug 31, 2019 04:34 AM
clscott84
Sep 21, 2015 10:16 AM
snowolson
Aug 31, 2015 03:51 PM
dwhipper61
Aug 27, 2015 11:01 AM
