2000 sportsman 500 shifting issue
I'm new to this site aswell as to being new to Polaris atv so hope I sound Stupid any this what I got. I reecently bought a 2000 polaris 500 sportsman
And some times if it locks in reverse or range. When I. First start it up. I runs great. As run at some speed or go into awd is when it locks up in low and. When I get of reverse to go to high it grinds. So I cut ignition off and all seems to be be well do I need to step on foot brake or does linkage. Need to be adjusted. I hope I. Didn't buy a lemon.
All help would greatly be appreciated
This was a common problem as the linkage and shift boxes wear. Have the gear box in neutral. Loosen the 10 mm linkage arm lock nuts at the gear box end. Remove the 10 mm nuts on both linkage arms securing it to the shift box levers. Turn the linkage ball ends to where they fall straight in the shift box levers with no resistance. Tighten the linkage arm 10 mm nuts and replace the two nuts that secure the linkage arms to the shift box. Hopefully this will help. Also if it's hard to shift or creeps while in gear you may need to shim out/remove shims on the rear clutch if the belt touches the front clutch sheath,to align it properly to where it rides in the center. If you haven't checked/changed the front hub fluid,it might be time to do so. It takes only Polaris Demand Drive hub fluid. You can also jack all four tires up and see if both front tires kick in when you engage the awd switch.
sportsman500nc
May 7, 2001 05:22 PM
