2001 polaris 500 magnum
Old Mar 31, 2013 | 08:15 PM
hhagen's Avatar
Default 2001 polaris 500 magnum
I have a 2001 polaris 500 magnum it runs fine how ever starting is an issue!! It will not start just turns over and over we checked everything, replaced battery took starter apart cleaned it put new carb on it! The only way it will start is if we hook a battery charger up and put it on jump mode!!!! Any thoughts????
Old Mar 31, 2013 | 08:23 PM
Seems like getting to be a common problem.I'd pull the recoil cover and clean the pickup(pulser) coil and any dirt/corrosion on the flywheel. Some would recoil start and not electric start. You might check this post out on a Sportsman that had similar problems. http://forums.atvconnection.com/pola...ml#post3155476
If this doesn't help you can ohm the white and white red pulse coil leads. Should show around 97 ohms.
Old Apr 1, 2013 | 09:36 AM
TLC's Avatar
TLC
I had that once . Like mentioned it was a dirty Pulse/Pick up coil.
Would start with pull rope but not electric.
Old Apr 1, 2013 | 02:45 PM
user493's Avatar
Moto Psycho
When mine would pull start but wouldn't electric start it was just a loose battery cable.
Old Apr 22, 2013 | 07:01 PM
hhagen's Avatar
Default 2001 500 magnum
Ok we have replaced the CDI, Starter, coil, spark plug, ignition switch, headlight/run switch, STILL NO SPARK...............HELPPPPPPPP
Old Apr 22, 2013 | 07:35 PM
Did you ohm out the stator and the pulse coil before you replaced all the other parts?? Sounds like the stator is the only thing left?
Old Apr 22, 2013 | 07:55 PM
hhagen's Avatar
Unhappy stator
Yes we did all that before replacing the others! How ever we have not since we replaced the bad switch! So it looks as if we will be going back into that area tomorrow!!! It would suck if that would be out know since that is like 400 to replace.....I was so excited when it tested fine the first time and the only thing that didn't test good at that point was the headlight/kill switch had a short....
Old Apr 22, 2013 | 08:36 PM
Check resistance out on either(which ever colors you have) the black/red to green OR black/red to Red wires coming from the stator leading to the cdi.Should show around 446 ohms + or - 20%. The pickup (pulser) can show to be good,but the main stator windings could be bad.
Cole Hadden
Jun 15, 2025 09:05 AM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 14, 2015 12:11 PM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 14, 2015 02:22 AM
