Bayou 300 carb issues
Old Apr 2, 2013 | 04:47 PM
muddbone's Avatar
Default Bayou 300 carb issues
I've been working on my 300 for some time. Bought it on a limited budget and finally have it starting and running. However, after running about 3-5 minutes, it accelerates to the moon and i have to shut it down. I've had the carb apart and it is clean now. Gasket on the bottom half has been replaced. Any ideas what may be causing this? Any help would be greatly appreciated.
Old Apr 2, 2013 | 05:55 PM
Jaster94's Avatar
i'm presuming the slide is in correctly seeing how it idles 3-5 mins, SO, with that in mind, it sounds like once things warm up, a vacuum leak appears. hmmm...wonder where it would show up? . have you checked the intake boot? does it have an O-Ring with a flange on the boot? is it facing the right way? i'm just thinking out loud here cause i haven't seen this problems before. maybe some others have.
Old Apr 3, 2013 | 06:48 PM
muddbone's Avatar
Thank you for the ideas. I'll be working on it again and will be checking on these. Thanks again.
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
JBibb
Jul 4, 2015 10:16 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Dabears1983
Jun 16, 2015 12:17 PM
