2003 Trail Boss Tranny Drain Plug
Old Apr 6, 2013 | 08:35 PM
rwa3474's Avatar
Default 2003 Trail Boss Tranny Drain Plug
I just bought a 2003 Trail Boss and want to change the oil in the transmission but I can't find the drain plug. My ATV has a solid steel plate under the transmission and there is a hole in the plate (similar to the hole in the plate to access the engine oil drain plug) but there is no transmission drain plug that I can see.
Can anyone tell me where the drain plug is?
Thanks....
Old Apr 6, 2013 | 09:27 PM
Drivers side of the gear case at the bottom. Item#35 Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Apr 7, 2013 | 12:43 PM
rwa3474's Avatar
My age must be getting the better of me.....I can't find the drain plug there?
Old Apr 7, 2013 | 12:50 PM
Sure you have a 2003 Trail Boss 330?It's down low at the bottom. Some early models also used a combo drain/transmission brace. They had a bolt and locking nut through the drain plug that had to be backed off. Can't remember what was the last year model to do this.Or you talking about the engine 6mm drain plug? Item #16 http://www.cyclepartswarehouse.com/f...2003&fveh=5623
Old Apr 7, 2013 | 02:46 PM
rwa3474's Avatar
That was it, mine has the combo brace/drain plug. My manufacture date is 12/2002 and it is registered as a 2003.
Thank you very much for the help.
Old Apr 7, 2013 | 06:06 PM
Just loosen the lock nut and turn the 9/16' bolt in far enough to remove the big drain plug. When you reinstall the drain plug,back the bolt out until it touches the frame,then turn 1/2 turn more and tighten the lock nut. Sucks I know on this type drain plug!!
Old Apr 7, 2013 | 09:22 PM
rwa3474's Avatar
Got it done. It was pretty easy once you helped me figure that out.
Thanks for your help.
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Shifts
Jul 3, 2015 07:59 AM
