2003 Trail Boss Tranny Drain Plug
I just bought a 2003 Trail Boss and want to change the oil in the transmission but I can't find the drain plug. My ATV has a solid steel plate under the transmission and there is a hole in the plate (similar to the hole in the plate to access the engine oil drain plug) but there is no transmission drain plug that I can see.
Can anyone tell me where the drain plug is?
Thanks....
Thanks....
Drivers side of the gear case at the bottom. Item#35 Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Sure you have a 2003 Trail Boss 330?It's down low at the bottom. Some early models also used a combo drain/transmission brace. They had a bolt and locking nut through the drain plug that had to be backed off. Can't remember what was the last year model to do this.Or you talking about the engine 6mm drain plug? Item #16 http://www.cyclepartswarehouse.com/f...2003&fveh=5623
Just loosen the lock nut and turn the 9/16' bolt in far enough to remove the big drain plug. When you reinstall the drain plug,back the bolt out until it touches the frame,then turn 1/2 turn more and tighten the lock nut. Sucks I know on this type drain plug!!
