250x top speed
Old Apr 29, 2013 | 04:37 PM
NGiff's Avatar
Default 250x top speed
What is the top speed of a 2008 trx250x? is it faster than a 2003 trx250ex?
Old Apr 29, 2013 | 08:34 PM
Scooter86's Avatar
Knows Old ATV Questions!
I don't know the top speed, but doubt it to be much more than 45mph. Stock v stock, the '08 with the sport clutch SHOULD be able to accelerate a bit faster while top speed should be the same. This is dependent on vehicle condition and rider skill of course.
Old Apr 30, 2013 | 10:55 PM
LittleMechanic's Avatar
Change the sprocket ratio around -4 teeth on rear and +2 up front and you'll get better acceleration and but no long run speed. But like Scooter said stock is around 45-49 mph. If you want more than sports clutches. Bigger carb. Bore it over and uni stage 2 air filter and you should gain around 5 or 10 mph.
Old May 1, 2013 | 05:23 AM
Scooter86's Avatar
LittleMechanic, the 250ex/current 250x is shaft drive. NGiff, you could alter final drive ratio by going to a taller tire for more top end. The trade off is it is a taller, heavier tire that won't handle as well and will bog the engine down a bit more.
Old May 1, 2013 | 08:27 AM
budedm's Avatar
If you want more top speed, you have the wrong quad.
Old May 1, 2013 | 07:00 PM
NGiff's Avatar
i just want to know if it will beat my friends 09 Honda recon and my other buddies 2000 Polaris sportsman 335.
Old May 1, 2013 | 11:59 PM
Jaster94's Avatar
a lot of variables come in to play here. terrain: what are your riding conditions? the 250ex is a good quad, but it is way light in the front end! it's 2wd semi automatic/sport clutch. what's your experience/skill level? how big are you? Weight/height/age...etc....if you're at 200 lbs and close to 6' tall, the trx250ex is not for you. think of it like this: any quad is slow enough to cruise and fast enough to hurt you when used incorrectly. drive smart. play smart. be smart.
Old May 2, 2013 | 07:13 AM
budedm's Avatar
Good Advice Jaster94. I was gonna say he'd beat the Recon but not the Sportsman, but what you said was way better. Play smart. It's not always about the speed.
Old May 5, 2013 | 02:55 PM
400EXrider02's Avatar
I agree with the 45mph statement. It is a beginner/smaller rider machine, wan't speed, get something with over 400cc's. My 400ex is stock and does like 65 topped out, but speed don't really matter to me, I need bottom end for climbing steep stuff...
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
