ITP Titan Trail Claw II
Old Mar 25, 2001 | 10:05 PM
ScoobyDFW's Avatar
I'm going to try the 22x11x10 ITP Titan Trail Claw II tires. I need a 22" tire on a 10" rim. I need the best hookup I can get in sandy conditions and in hard, dry torn up mixed grass/dirt conditions, while maintaining good hardpack performance. The trail claw II's are light, and have widely spaced tread. They may not be the hardest rubber for long wear and they may not be the most puncture resistant either. I might run a second set of tires such as 22" realtors or 22" holeshot XCT's.
http://www.tiresunlimited.com/images...railClawII.jpg
Old Mar 26, 2001 | 08:47 AM
dskurt's Avatar
I have 22x10x12 Realtors. I have never rode in sand, but in every thing else they give extreme straight line bite. Powersliding isn't bad, but they will break loose and grab again. All and all MEAN tire and I think they are worth the money.
A guy I met at a race swore by Trail Claws for hillclimbing. He had 2 or 3 years on them and they still look pretty good. Later, Kurt
Old Mar 26, 2001 | 01:43 PM
TRAIL's Avatar
are trail claws a low pro tire?the pic looks more like a balloon tire but i have seen a pic of a shee with them.....which is right?
Old Mar 26, 2001 | 09:59 PM
burbanator's Avatar
Scooby, I am currently running the trail claw II,and i can say they have excellent straight line traction in all kinds of soil. I live in Montana and found that the stock tires sucked in any kind of snow. Now i can climb hills in 8 inches of snow with little effort. Some times they almost hook up to well like on a hole shot you might find yourself pulling the clutch and hitting the rear brake to keep from flipping it and thats sitting over the tank!! The downfall to these tires i would say would have to be turning stability, it feels like the tire wants to roll under due to the tires lack of a flat tread. Im also runnung these tires on a nine inch rim, they might not be as bad with a 10 inch rim due to the sidewall being shorter! Hope that helps answer any question you might have had!
Old Mar 26, 2001 | 10:16 PM
ScoobyDFW's Avatar
burbanator, Are you running the 22" tires? Does the tire pressure affect how flat of a profile the tire has? What psi are you running?
Old Mar 27, 2001 | 12:13 PM
dhenricks's Avatar
I was looking for a tire that would also work in Snow along with mud look soil. Any suggestions.
Old Mar 30, 2001 | 12:32 AM
burbanator's Avatar
Scooby, my tires are 22x11-9 and i run 5 psi in them, and im running 23x7x10 itp xct up front. Ive tried different pressures in the rear and 5 psi seems to work the best all around!
Old Apr 2, 2001 | 05:15 PM
hou650's Avatar
I replaced my stock tires with 22x11x10 surtracks and they worked well an all types of soil, thought there wasn't a better tire out there. Until bought a set of 22x12.5x10 spidertrscts. The differance between the surtracts and spidertracts was like going from
the stock tires to the surtracts. INCREDIBLE TIRE
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
Alex Rodak
Sep 11, 2015 11:42 PM
craacker
Sep 9, 2015 04:32 AM
awer1968
Sep 8, 2015 11:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
