New front suspension
Old May 6, 2013 | 10:27 PM
Nelson86's Avatar
Default New front suspension
Well my '00 sportsman 500 front shocks are about to the end of there life. It has the macpherson front struts and from what I understand are non-rebuildable. I would rather do some upgraded front shocks instead of buying another set of macphersons. I would like to keep it reasonably priced. I've seen Bronco front shocks for sportsman that are for my model, Are they worth the extra $50 and how good are they? Do the broncos come with springs or do you have to remove your existing ones?
Thanks
Old May 6, 2013 | 10:43 PM
Nelson86's Avatar
Would any other year of sportsman shocks possibly work with a little bit of fitting? Or maybe just buy new shocks and springs? If I do that what shocks and springs will get the most travel?
Old May 7, 2013 | 08:15 AM
TLC's Avatar
TLC
On mine the front was to soft all I did was add HD springs from polaris and it stiffend it right up better then new.
I bought the Polaris HD but there are aftermarket ones as well. There about $100 a pair.
The 96 to 2004 should be all the same after that there was a front suspension travel increase.
Old May 7, 2013 | 02:28 PM
Nelson86's Avatar
K, those aren't going to stiffen the suspension to the point they won't move for smaller bumps at all will they? How are those when doing jumps? I probably will get a pair of those but I'd like to know
Old May 7, 2013 | 02:39 PM
Others that do a lot of jumping can advise you,but I installed quite a few of hd springs for front and rear of Sportsmans,Scramblers,etc. Didn't have any complaints on being too stiff plus on a lot of front ends where the tires seemed to lean inward after awhile,hd springs helped on tire alignment since you can't adjust the camber on Polaris front ends,just the toe in and toe out.
Bratman2
Aug 6, 2022 01:42 AM
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
carolinabomb
Jul 26, 2015 08:40 AM
Jkfx400P
Jul 6, 2015 10:04 AM
