Mixing polaris 2 cycle oil
Old May 25, 2013 | 08:58 PM
tekrsq's Avatar
Default Mixing polaris 2 cycle oil
Does anyone know if I can mix Polaris 2 cycle oil straight into the gas or does it have to go through their oil injection system. If I can straight mix it, how much would I need per gallon for a 32:1 and 40:1 ratio.
Old May 26, 2013 | 03:56 AM
You can premix Polaris oil along with most other good quality 2 stroke oil. Usually says on the bottle premix or injector applications. Premix at 40-1.
Attached Thumbnails Mixing polaris 2 cycle oil-pol_13_syn_ble_2cy_oil_32_oz.jpg
Old May 26, 2013 | 06:04 AM
tekrsq's Avatar
Thanks OPT !! Can I premix injector oil ?? I guess I should have been more clear. I have plenty of injector oil laying around, but I want to do away with oil injection on the predator 50 (the oil pump is shot). So I was hoping I could still use it up instead of having to buy more oil.
Old May 26, 2013 | 07:58 AM
Just look at the bottle label you can use it either way,same as for most other 2 stroke oils.
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
CRamshaw777
Jul 18, 2015 05:46 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Shifts
Jul 3, 2015 07:59 AM
