93 polaris 350l won't start
Old May 27, 2013 | 06:25 PM
Tony Jones's Avatar
Default 93 polaris 350l won't start
Hi I'm new to the site I have a93 polaris trail boss 350l I rebuilt the top end and I had it start one time since then but when it started it was in reverse we shut it off quick pit it in neutral and can't get it to stat again is there some kind of safty switch were it will only start in neutral
Old May 27, 2013 | 06:58 PM
Pull the black wire from the reverse limiter module and see if it helps. When faulty they can die when you put it in gear or won't start in gear. You will then have full power in reverse without having to push the over ride button. Item #34 is the limiter under the tank cover down from the headlight. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old May 27, 2013 | 07:06 PM
Tony Jones's Avatar
Thanks ill try that hopefully that's it I bought it pulled the motor apart and rebuilt it haven't been able to ride it yet
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
cornermike
Jun 3, 2015 07:27 AM
cornermike
May 28, 2015 09:47 AM
1000gade
May 27, 2015 12:37 PM
