400ex- Ground Clearance
Old Mar 26, 2001 | 11:03 AM
RotGutBottom's Avatar
I tell ya- I feel like I scrape my swing arm / back end on anything I go over. I'm thinking about getting a skid plate- but I don't want to reduce my ground clearance. Is there a way to raise my back end a few inches?... or would this raise my center of gravity to unstable heights?
I guess I could loose some weight. I got about 40 lbs to spare - ..but I'm looking for a faster and easier way out of this.
If I stiffen my rear suspension- would this reduce the sag and increase my ground clearance?
Thanks!
Old Mar 26, 2001 | 07:44 PM
Michaud68's Avatar
I raised mine by getting new tires I went with 22x11 in the rear and 23x7 in the front both maxxis Razors this will raise it 1 inch also recommend a swingarm skid.
Old Mar 26, 2001 | 08:23 PM
86atc250r's Avatar
A set of 20" Holeshots or RAZRs will increase your swingarm to ground clearance at least an inch... I know what you're thinking "My stock tires are 20".. Trust me on this one. That inch makes a big difference.
Old Mar 27, 2001 | 09:54 AM
Ford4x41995's Avatar
just put 22" tires on it
Old Mar 27, 2001 | 12:17 PM
YZGUY's Avatar
My 400 hit everything with the stock tires. I could run down a trail on a Warrior and never hit anything. Then I would run the same trail with the 400 and hit several times. I now have ITP XCT tires 22" rear and 23" front-they are great.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
salixair
Nov 3, 2015 08:25 AM
Sw00p
Sep 24, 2015 02:50 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
