Kawasaki Bayou 300 Ignition Issues
Old Jun 3, 2013 | 09:33 AM
jake6995's Avatar
Default Kawasaki Bayou 300 Ignition Issues
My bayou 300 will intermittently run rough when I hit the throttle, but it idles fine. Here are some checks I did when it was running good:
I checked out the 3 yellow wires from the alternator- at idle I have 18 volts AC between 2 of the legs but 0v on the 3rd.
Alternator resistance reads, 0.6ohms, 0.6 ohms, and 0.2 ohms on the 3 legs
Battery voltage is 13.5v
coil when warm ohms out at 3.4 ohms
When running bad
the alternator voltage reads 18v AC at idle
battery voltage 13.5v
coil when warm ohms out at 3.2 ohms
I put a timing light on it and when idling it sparks normally, but when I hit the throttle it sparks slowly like maybe twice per second. My timing light reads RPM based on spark and when idling it reads 1000 rpm, but when i hit the gas it drops to 500 rpm which indicates less spark.
It will act up for a while and then it will start running good again after about 5 minutes.
Any ideas on what could be wrong?
Old Jun 4, 2013 | 09:52 PM
Sykwidit's Avatar
Did you reset the timing ever? Vavles being off will cause wot fail. As soon as you give it vas chokes off. Also ngk plugs foul real easy. Mine did this not long ago. Check the timing it was off 180 fix it. Then we had a wot prob plugs was fouled. Then we check the exhaust vavle and intske they where off by by a good 10mm. Think on klf intake 10-15mm and exhaust 15-20.
Old Jun 5, 2013 | 12:33 PM
jake6995's Avatar
I did reset valve clearance and check timing. I'm assuming it's something electrical since it's an on and off symptom. It will go into a mode where it won't rev up at all and then it will kick out of it instantly. Any other thoughts?
Old Jun 5, 2013 | 12:48 PM
Sykwidit's Avatar
Could you upload a video? Klf300 has the cdi the stator solinded, coil, plug. Change the coil out and plug. I had a plug fouled and swear is wasn't. Spark was awesome put a old plug in last night and she fired up. My wot was cause of vavles though so we set it 10 intake 20 exhaust. Shot for the coil if you where close I have a spare u could have. I have the pdf on our quad. I will pm you the link might help more.
Old Jun 10, 2013 | 09:53 PM
jake6995's Avatar
Thank you for the pdf. I tested the pickup coil and ignition coil and they are testing good. The CDI box doesn't ohm out correctly. I'm guessing that is the problem. I'll replace it and see if it works. If not, I'll upload a video.
Old Jun 10, 2013 | 09:59 PM
Sykwidit's Avatar
They are not cheap. So might want to out source on here or site for price. I know my local kawasaki dealer quoted me something around 260ish. Good luck glad it helped.
Old Oct 29, 2017 | 12:50 PM
David Akkerman's Avatar
Default New ignition coil
Hi , I have a 90 bayou 300 ..2 wheel drive...changed ignition coil..old one had a green wire on one terminal and a red/ yellow wire on the other..new coil had a black wire jumped from one terminal to the other , then one black wire coming off...did I maybe get wrong coil...or any ideas how to connect
Old Dec 2, 2017 | 11:59 AM
Nick Baleria's Avatar
Hi David Akkerman, I just order the same coil I think, plus I ordered a new cdi and rectifier. Did you figure out what leads go where? I was guessing and took off the black leads. No spark and no voltage at either green or red yellow wire while turning over. Looks like those wires lead back to the cdi? If you don't mind letting me know if you found anything out for it looks like this $7 coil should work for us somehow? Thanks, Nick
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
