94 Yamaha Big Bear 350 4x4 clutch problem?
Old Jun 6, 2013 | 02:41 PM
PJW25's Avatar
Default 94 Yamaha Big Bear 350 4x4 clutch problem?
I need help, when I put it in gear it clunks and moves foward and you have to give it gas to keep it running. Also, it shifts real hard between gears. Is this a clutch problem and needs to be replaced? Any help would be great, Thanks!!!
Old Jul 28, 2013 | 09:22 AM
hermie's Avatar
you need to adjust the slack in your clutch cable
you clutch is not fully dis-engaging when you pull the clutch lever
check the inline fuel filter to your carb, sounds like it is close to being plugged up
also pull the cylinder head cover , you may need to adjust your intake / exhaust valve clearance
drain your engine oil and replace with oil meant for wet clutches
i personally recommend SHELL ROTELLA T6 synthetic diesel engine oil
i used the conventional rotella in my old ninja 600 bike , makes a hell of a difference in engine smoothness and smooth clutch shifting
not to mention a cooler running engine
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
volsgo30
Jun 4, 2015 06:07 PM
finbone
Aug 29, 2000 04:46 PM
250Man400
Jun 28, 2000 08:57 PM
clayman
Jan 25, 2000 05:57 PM
