swamped???
Old Jun 11, 2013 | 06:53 PM
mad-atver's Avatar
Exclamation swamped???
i have an 05 sportsman 500 and i got in a pretty deep water hole and i got stuck, then she seemed like she wanted to die then it stalled!!!! the front end was sitting higher out of the water but the water was almost up to the rack at the rear. we pulled it out of the water and i pulled the plug out and turned it over a few times, but no water was spitting out the hole, but water was running out the tail pipe. the oil is not milky at all either what should i do next?
Old Jun 11, 2013 | 07:46 PM
Mongrol's Avatar
"Official Site Skeptic"
Pick a dryer area.
Old Jun 11, 2013 | 07:51 PM
papahouse's Avatar
Stand it up and drain the water out of the exhaust and it should start. Also check your belt housing for water
Old Jun 11, 2013 | 07:56 PM
If there wasn't any water spitting out and the oil isn't milky you probably didn't inhale any water, as you are thinking. I'd check electrical connections by finding them and pulling them apart to see if any have water in them. I'm sure there are other things to try but this is my thought. If you find any, dry them out and put dielectric grease on the fittings to keep any more water to get into them.
Old Jun 11, 2013 | 08:10 PM
GripNRip's Avatar
That's has happened to me a couple of times. Is it EFI?
Old Jun 13, 2013 | 01:48 AM
switzomatic's Avatar
Check the airbox as well.
Old Jun 13, 2013 | 02:38 AM
Would be the first thing on my list to check along with any water contamination in the engine oil,transmission or front differential fluid that could have come in through the vent lines.
Old Jun 14, 2013 | 12:31 PM
mad-atver's Avatar
i stood it on end and drained it, i changed oil, the filter seemed a bit wet but it seems to be running good.
Old Jun 16, 2013 | 02:30 AM
If the filter got wet then there are a few things to look at. From what you said the front was up higher. The intake draws air from just above the front of the seat. If that wasn't under water then check the airbox seal and make sure the drain tube under the airbox has the plug in it.
shimanok2
Jan 29, 2016 07:37 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Sep 10, 2015 01:56 AM
1000gade
Sep 9, 2015 03:35 PM
