Eiger gas in Crank case and airbox and now won't start
Old Jun 17, 2013 | 01:48 PM
Punchybiscuit's Avatar
Default Eiger gas in Crank case and airbox and now won't start
OK so I have a 2002 Eiger. I was riding it up my yard when it just shut off and died and would not start. When I checked the plug it was black and there was lots of fuel in the air box. I check the oil and it was full of gas also. I cleaned the carb because i assumed the float got stuck and changed to oil of course. Now I can not get my eiger to fire up. I do have good spark so it must be a carb issue. Is there adjustment I am missing or something Please help me!!!!!
Old Jul 24, 2013 | 04:37 PM
hermie's Avatar
check to be sure that your carb floats have not absorbed any fuel
the older plastics used were never made to tolerate ethanol or cleaners in the fuels
these 2 additives just eat away at those plastics
there are newer carb rebuild kits with new floats that tolerate the newer fuels
the fuel inlet valve is jammed open ( fill )
Old Nov 19, 2013 | 08:21 AM
frootloop's Avatar
Mine done the same thing I cleaned the carb and put a new pit **** in it solved the problem good luck.
neilbedwell
Nov 10, 2018 11:02 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
Dabears1983
Jun 16, 2015 12:17 PM
1000gade
May 27, 2015 12:37 PM
