HAVING CARB ISSUES! here are some tips
Old Jul 1, 2013 | 03:20 PM
hermie's Avatar
Default HAVING CARB ISSUES! here are some tips
#1 check your fuel tank cap rubber gasket
remove the gasket and apply a film of lithium grease to both sides and then re-install
the oils in the lithium grease help keep the rubber gasket soft and supple
and aids in sealing the fuel tank
#2 replace your older style rubber fuel line with a new synthetic rubber fuel injection hose
( the older style rubber fuel line deteriorates quickly when it comes in contact with the cleaners/ethanol mixed in with gasoline )
#3 switch to a small cyndrical style motorcycle style fuel filter
( these type of fuel filters have a 1 way check valve ,)
when the fuel bowls fills up , the fuel then backs up into the filter , the check valve closes stopping any more fuel flowing through it , until the fuel level in the bowl drops
motorcycles have been using these type of fuel filters for years
#4 keep your fuel line routed away from the engine , even synthetic rubber melts when it contacts hot metal
# 5 position your fuel filter as close to the carbs fuel inlet as possible , any internal parts of the rubber fuel line that deteriorate and separate from inside the rubber fuel line then enter the carb bowl and cause blockage will be minimized
#6 over time , the small choke valve inside the carb body will jam with exposure to heat
periodically remove the choke piston and lubricate it with some 2 cycle oil
you may think your choke is off , but it may actually be stuck in the ON position in the bore
and finally #7 periodically remove the needle plunger and lubricate it
i cannot count how many people i have told to lubricate that part
because that part moves up and down , it does require lubrication now and then
Jmuddin284
Jan 19, 2026 07:16 AM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
