no throttle adjuster on chinese carb
Old Aug 8, 2013 | 11:24 PM
fmv75's Avatar
Default no throttle adjuster on chinese carb
my dad has 83 Honda 185s and he ordered a Chinese replacement carb.it mounted to the motor fine but there is no throttle cable adjuster on the top of the cap .it just has a hole and rubber boot ,that's it.anybody else run into this?
Old Aug 9, 2013 | 06:12 AM
Jaster94's Avatar
man i don't quite understand what you're talking about. most throttle cable adjustments are made on the turnbuckle itself or up at the thumb throttle. go along the throttle cable and look for a fat part with a soft rubber boot covering, peel that back and you should see the turnbuckle to adjust the cable.
Old Aug 9, 2013 | 06:39 AM
fmv75's Avatar
you'r right jaster,i worded that crazy.what I mean is, the cap is not threaded to recieve the turnbuckle.its just smooth.are we supposed to thread it ourselves or would we need the same brand cable to work with it ?my dad also just recieved a Chinese carb for his 84 Honda 200m and it has the same exact probem.
Old Aug 10, 2013 | 12:43 PM
fmv75's Avatar
is there a trick to connecting stock atc throttle cable to Chinese aftermarket carb.please help!!
Old Oct 30, 2013 | 12:17 PM
MonkOFox's Avatar
I have a chinese carb for my 85 200s and it was threaded for the throttle cable cap. I'm not sure what's going on with your stuff. Pictures?
Jmuddin284
Jan 19, 2026 07:16 AM
Frisky2050
Apr 9, 2020 11:19 AM
tweeder
Jul 5, 2015 01:57 PM
Mikea1978
Jul 4, 2015 12:37 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
