woods carb help?
Old Mar 27, 2001 | 06:59 PM
Jimmie's Avatar
OK fixed the woods stage 1 kit carb problem with the hesitation. NOW can we ds riders get a solution to the hard twisting throttle the kit comes with, the carb spring is too strong for reasons beyond me, lets after-mod it to work, help me you guys. springs and different positions?
Old Mar 27, 2001 | 08:17 PM
Knutz's Avatar
This problem seems to be coming from Mikuni instead of coming from Ron Woods. I currently carry Mikuni TM series carbs[as apposed to HRS series from Woods] to sell for Team Pami and have the same issue with the twist throttle version.I was going to try removing the pin that holds the left side cam onto the throttle shaft so I could unwind the spring one or two turns. This should lessen the tension on the throttle. Then press then pin back in place to re-install the cam.
By the way jimmie, the carb worked much better for me without the acc. pump.
Old Mar 27, 2001 | 11:55 PM
sandsurfer's Avatar
Knutz
Can you gie me so information on the Mikuni TM Carb? Where can I purchase one?
Old Mar 28, 2001 | 01:32 AM
Knutz's Avatar
From outside looks, the TM seems to be the same as the HRS. Team Pami uses the TM and I have it in stock with the twist throttle. Mikuni may be able to give you more details about the difference between the two. If you would like to order one, please e-mail me and I'll get it off to you. Thanks
Old Mar 28, 2001 | 08:50 AM
Jimmie's Avatar
hey knutz i thought the same thing but didn't want to chance f'n up the spring, let me know if you try it. and the pump fixed my response problem off idle, maybe your 760 didn't need it.
Old Mar 28, 2001 | 08:51 PM
mtecate4g's Avatar
Hey jimmie you still got your stock carb? Wanna get rid of it? Give me a good deal on it. remember who hooked you up with a good deal on a ds650 jacket ;o)
Old Mar 29, 2001 | 02:28 PM
Jimmie's Avatar
sure mtecate4g make me an offer.
Old Mar 29, 2001 | 08:29 PM
Jimmie's Avatar
knutz i'm gonna try a spring off a ski-doo snomobile carb, it might just do the trick.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Bratman2
Jul 25, 2015 07:16 PM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
