CanAms getting famous 4 clunking sound from rear
Old Oct 2, 2013 | 09:52 AM
UTU's Avatar
UTU
Angry CanAms getting famous 4 clunking sound from rear
On my 2013 Outty 1000 xt AND OTHERS sway arm bushings( cushions) were a lil loose (Attached to frame CanAm parts #706001098) . Pumped em full of grease.Poor design on sway bar bushing does not take grease all the way around. Took a while for grease to work around. Greased-rocked-greased-rocked-etc-etc. Finally no more clunk. I will be looking at the after market bushings and hopefully a better design on main sway bar THAT takes grease. (Easy 60 year old rider.) Rides trails checking feeders and cameras and hunting. Low miles and hours (EASY ONES). Shame to be clunking this soon/AT ALL...... Perry
Old Oct 23, 2013 | 07:44 AM
IronBear's Avatar
PF Powersports LLC
I recently had the same issue with my machine. The bolts were loose which caused the rear sway arm cushions on one side to go bad. With that being said, I ordered both left and ride side cushions from cheapcycleparts.com for just under $14.00. I'm going to install them this weekend, and put lock washers on the housings so that the bolts don't come loose, then grease all the fittings. Further, I'm going to make sure all the bolts are tight like they should be.
Other than the above issue, the machine has been great! I have just over 900 miles on mine.
Old Oct 24, 2013 | 08:48 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
Haven't noticed that yet on my 2013 1000 max xt...
Old Oct 25, 2013 | 09:51 AM
TLC's Avatar
TLC
Wink
Give it time ,give it time, it's coming. Its just waiting for you to get 20 miles from the staging point.
Old Oct 25, 2013 | 03:07 PM
1eep's Avatar
The fronts aren't better....I have two front a arm bushings that are stArting to have slop after one year of mild riding by a little old man.
Old Mar 1, 2014 | 09:13 AM
UTU's Avatar
UTU
Replaced all the bushings and sway bar bushings from PapaJohn over at Garage Products Garage Products ATV bushings. Quality bushings and great to work with. No more popping. (:>
Tomtom86
Aug 7, 2024 07:40 PM
STLyamwar
Jul 25, 2020 04:44 AM
brad wheeler
Jul 13, 2015 11:19 PM
rcappie4
Jul 10, 2015 04:54 PM
coolguy420
Jul 10, 2015 01:17 AM
