2009 Prairie 360 Stalling
Old Oct 7, 2013 | 07:37 PM
Big A's Avatar
Default 2009 Prairie 360 Stalling
Okay so my 2009 Prairie keeps stalling when slowing down and coming to a stop. It NEVER did this before. Then it will take me a long time, sometimes 2-3 minutes to get it restarted. I recently serviced it myself and the only things I did not get a chance to replace or change yet are the fuel filter and the spark plugs. Is there any reason for this or do I probably just need to replace the fuel filter and spark plugs? It ran perfect two times after I serviced it so I know I did nothing wrong.
Old Oct 7, 2013 | 07:50 PM
Cummins Driver's Avatar
Does it kind of jerk to a stop as it kills the engine? Sounds like the engine braking system is not releasing the primary enough (or at all) as you come to a stop. Does it crank over slow after it dies or does it crank normally? You could always start it and unplug the little motor on the belt cover that controls engine braking. That would eliminate that as an issue.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 16, 2019 02:24 AM
cboler9
Sep 24, 2015 08:35 PM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
