04 sportsman 400 speedometer & cluster out
Old Oct 8, 2013 | 06:19 PM
laneman's Avatar
Default 04 sportsman 400 speedometer & cluster out
I have an 04 sportsman that the speedometer and digital cluster went out. The digital cluster had been flashing previously. Sometimes had to wiggle power switch to start. Still starts & runs. Any thoughts?
Old Oct 8, 2013 | 07:03 PM
Check the wiring under the headlight pod. This is the area where most shorts happen because of all the twisting and turning. Could be as simple as the switch connector or harness short or the main connector wiring going to the speedo. Bad area also for the yellow high beam headlight wire and ground(brown) wire problems.
Old Oct 8, 2013 | 07:09 PM
laneman's Avatar
Thanks. Took the top off for quick inspection but did not notice anything out of order. Will check closer this weekend. Didn't know if there was a fuse I could check or not.
Old Oct 8, 2013 | 07:27 PM
You have to dig deep to sometimes find the problem if it's a wiring short. There is a 20 amp thermal circuit breaker in a sealed pouch up from the battery usually tucked under the rear fender.They can cause problems if the connections are corroded. To eliminate it as the problem you can slice the pouch open and check the two terminals,if ok,just silicone the connections and tape the pouch back up. If in doubt about it you can get this breaker at most auto stores for a few bucks.
Old Oct 9, 2013 | 01:03 PM
lowflyer's Avatar
The brown ground wire for the speedo ties into a splice with 3or4 brown wires on the way to the ground at the coil. Mine had a problem here (it`s an `02)
Old Jan 2, 2014 | 01:36 PM
laneman's Avatar
Okay. Replaced speedo cluster , still nothing. Have voltage to big connector. No voltage to 3 wire plug ( red,white,black ). Any suggestions ? Thanks for your help. Ready to jump wires for AWD ANYWAY.
Old Jan 2, 2014 | 04:29 PM
Try this if you haven't already.
Plus are you talking about the hall effect sensor harness for the speed sensor?
Jmuddin284
Jan 19, 2026 07:16 AM
cdstang
Aug 31, 2015 07:52 AM
tropicalnuts
Polaris Side by Sides
Aug 22, 2015 11:08 AM
400H0
10
Aug 20, 2015 07:34 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
