1998 bayou 300 4x4 valve clearance?
Old Oct 11, 2013 | 12:12 AM
Jamie123321's Avatar
Default 1998 bayou 300 4x4 valve clearance?
I trying to adjust my bayou's valves but I can't seem to find the right clearance
I found 0.03 to 0.05 intake 0.06 to 0.08 exhaust
0.10 to 0.15 intake 0.15 to 0.20 exhaust
And 0.59 to 0.79 to 0.71 to 0.91
I have no idea on the one to go with
Old Oct 11, 2013 | 09:36 AM
TLC's Avatar
TLC
intake, 0.10 to 0.15 mm; exhaust, 0.15 to 0.20 mm. (In millimetres )
Instructions
How To Set Kawasaki Bayou 300 Valves | Made Manual
Converted to inches.
.10mm = .003937 inch
.15mm = .005905 inch
mm times (x) .03937 = inches
Old Oct 11, 2013 | 11:13 AM
Still no luck on starting it cleaned the carb 5 times adjusted valves made sure I was on the compression stroke and not the exhaust changed spark plug and checked for spark cleaned tank and petcock and put fresh gas checked for compression new air filter check the battery
Turns over put won't crank
Old Oct 11, 2013 | 11:24 AM
Oh and checked the timing chain and timing marks to make sure everything lines up
Old Oct 11, 2013 | 03:37 PM
sr.ruedas's Avatar
Time for a compression test. You need at least about 90 psi and a good spark.
My own Bayou 300, an 87, was so dusted that it needed a new piston.
The photo shows the intake valve after cleaning and lapping. Hard to
see, but the seat has been worn way into the head. Not quite enough
to keep me from setting the valve lash to spec, however.
Old Oct 12, 2013 | 01:48 AM
backfires through muffler.i will check the compression in the morning
Old Oct 12, 2013 | 08:39 AM
MrSummit's Avatar
You cleaned carb plenty. Did you happen to check the float level measurement and do the clear tube verification for actual level? I don't know if that's the cause, but might be?
Another thing I've come across - the petcock and tank on my daughters xr70 were gummed up with black tar like crud from the bike sitting on dealer showroom floor for a few years before I bought it. It was new. Was causing my carb to plug up all the time and I kept cleaning carb, then discovered the tank deal.
When you say it won't crank, I assume you mean it won't start.
Old Oct 13, 2013 | 02:23 PM
Thanks for all the help and suggestions but still no luck on starting it
Old Oct 16, 2013 | 09:24 PM
I found the vin number and looked it up
It says I have a 92 instead of a 98 like I was told when I bought the atv
Are the valve clearance still the same?
Old Oct 17, 2013 | 06:47 PM
MrSummit's Avatar
many times I've seen the valve specs on the bottom of the seat, sticker, or on the frame.
