1st timer-carb cleaner prob
Old Oct 13, 2013 | 12:41 AM
Babbles's Avatar
Default 1st timer-carb cleaner prob
2000 Rancher ES (TRX350FE) I got it all put back together but I have this medium sized spring left. (Not big spring on slide, not the tiny one on the pointy thing) Cranks, but only with choke. PLUS, it's steady leaking gas out overflow! OK, don't laugh. LOL. yes I'm female. It was fun... So, any helpers out there? It might be spring or the float stuck. May need to grab carb kit and rebuild. Help!
Old Oct 13, 2013 | 06:59 AM
Scooter86's Avatar
Knows Old ATV Questions!
A lot of online vendors sell oem parts and have parts diagrams on the web to look at. That should help place your wayward spring.
Old Oct 13, 2013 | 09:56 AM
Babbles's Avatar
Thanks Scooter86. I appreciate it. Will look for sure!
Old Oct 13, 2013 | 12:02 PM
Babbles's Avatar
Okay placed the spring (inside primer pump-a-ma-gig), doesn't leak gas out the overflow anymore. YEAH! Now trying to get it to stay cranked without having to have choke on. Any ideas?
Old Oct 14, 2013 | 07:14 AM
drivers1492's Avatar
Check for vacuum leaks on the carb boots front and rear thats about the most common place to crack when your pulling and replacing a carb. Since it runs full choke only your restricting airflow. Did you twist out the idle/mix screw when you had it off?
Old Oct 14, 2013 | 08:10 PM
kormos_93's Avatar
Adjust the fuel/air mix screw (long brass needle) but don't over tighten or it will break the end off. Should be a couple of turns out....adjust at fast idle.
Old Oct 16, 2013 | 10:00 PM
Babbles's Avatar
Thanks drivers1492. I had carefully gauged the mixture screw prior to this. So, I knew it was something. It was still a clogged pilot jet I believe. Plus I changed other parts like gasket and pivot. I really seated the carb better this time too.
Old Oct 16, 2013 | 10:07 PM
Babbles's Avatar
Thanks drivers1492 and kormos_93. Ya'll are great to help out a nubbie like me! Ended up not having cleaned pilot jet we'll enough. While had it apart replaced sad looking pivot and rubber gasket. AND I drained tank,put new gas line, in line fuel filter and new cut off valve. Placed ethanol free gas in tank. Adjusted mixture screw and idle. Now PURRRRRRRSSS. IDLES WONDERFULLY!!! I'm so proud to have done it myself. Thanks to YouTube videos by d-ray he's awesome
Old Oct 17, 2013 | 08:50 AM
Glad you got it running
pgamboa
Dec 24, 2023 11:52 AM
2many2ride
Sep 27, 2015 04:35 AM
BigCam
Sep 16, 2015 01:53 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
rawbdiggity
Sep 7, 2015 12:05 PM
