cant get flywheel off with puller
Old Oct 24, 2013 | 08:38 AM
ulmanb's Avatar
Default cant get flywheel off with puller
2002 Warrior, So I bought a flywheel puller and the flywheel still doesnt budge using a impact gun.
I tightened it up and then gave the bell of the flywheel a few quick raps with a hammer hoping with the tension and impact it would loosen, no luck.
My main purpose was to replace the timing chain while doing a top end rebuild because the piston hit a stuck valve, figured it may have given the timing chain excess stress.
One thing I did note is that the end of the crankshaft is hollow and the puller doesnt sit well on the end of the shaft when tightening, but If I try and throw a spacer, washer, or bolt over the end, I cannot get the puller to screw onto the flywheel base as the puller isnt long enough.
Any suggestions? Sucks, have a flywheel puller that didnt work, and a new timing chain to install that I cant. Most likely am just going to reuse the old timing chain and move on.
Old Oct 24, 2013 | 08:56 AM
TLC's Avatar
TLC
Seems like Yamaha needs a one of a kind flywheel puller.
This is a 600 but its a similar flywheel to the 350.
Old Oct 27, 2013 | 09:03 AM
traderdan's Avatar
[quote=ulmanb;3217580]2002 Warrior, So I bought a flywheel puller and the flywheel still doesnt budge using a impact gun.
Any suggestions? Sucks, have a flywheel puller that didnt work, and a new timing chain to install that I cant. Most likely am just going to reuse the old timing chain and move on.[/quote
Old Oct 27, 2013 | 09:10 AM
traderdan's Avatar
I used a harmonic balancer puller had to buy 8 mm bolts to screw in to flywheel but it worked great on a bear tracker 250
Old Oct 27, 2013 | 09:55 AM
chris64's Avatar
Try pry bar underneath flywheel while you tap with hammer.
Old Nov 6, 2013 | 10:18 AM
ScootersScooters's Avatar
We used a slide hammer with a bolt puller when we removed the cover on our Grizzly 600. It made a huge difference. Wouldn't do it any other way.
It sounds like we went through the same process you're going through now. We wrote about the process and included photos on our website. I included the link below.
Bad Timing (Chain)
Old Nov 7, 2013 | 06:28 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
put tension on the puller than hit the head of the bolt on the puller
Old Mar 1, 2014 | 08:58 PM
fastfish408's Avatar
How is the flywheel replaced? Im not sure mine is going back on far enough.
chingchangchong
Aug 7, 2022 11:36 AM
Joe454
Nov 20, 2020 01:19 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
raman8tor
Sep 20, 2015 07:35 AM
