temp sensor
Old Oct 29, 2013 | 12:46 PM
mick mcleod's Avatar
Default temp sensor
I have been thinking about adding a temp sensor to my 04 sp400.I have the whole gauge kit new in package sitting around,was wondering if I could add a small piece of steel pipe in one of the rad hoses instead of tapping the thermostat housing.Better to screw up a 2 dollar piece of pipe than the housing.If so does it matter what hose,upper or lower.And anyone know the I.D. of the hoses?
Old Oct 30, 2013 | 05:48 PM
didnt get any replies about this one,hmmm not even OPT.
Idi see a video on youtube,the guy did the same thing as I was asking about,looks good to me,the guy in video kept his as close to thermostat housing as he could,i guess for a more accurate reading.
Old Oct 30, 2013 | 05:56 PM
Best I can remember it's about a 1" to 1 1/4" od with a 3/4" id. If in doubt just remove the hose and and see where you stand on whether you have to modify the temp gauge fitting to work.
Old Oct 30, 2013 | 06:06 PM
thanks OPT.I figured I could just buy a 3/4 gal.tee at hardward store,and match up a bushing to accept the sensor,should be pretty standard sizes,then just clamp both ends of rad hose to nipples threaded into the tee,seems like a pretty straight forward plumbing job to me.would keeping it as close to thermostat as possible help with a more accurate reading on the guage,and do you happen to remeber the operating temps for 04 400 sp
Old Oct 30, 2013 | 06:24 PM
Fan off at 165 degrees. Fan on at 185 degrees. Every machine will vary,but between 140-160 degrees should be an average.
Old Oct 30, 2013 | 06:31 PM
Thanks for the input once again OPT,now I just have to decide its it worth it to do the mod,seems practical to me,and a pretty cool weekend project to get me out of the house
Jeff Roper
Feb 1, 2022 11:48 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Jeff Roper
Sep 21, 2015 02:11 PM
