OP,another awd QUESTION
Old Nov 3, 2013 | 01:19 PM
mick mcleod's Avatar
Default OP,another awd QUESTION
Been reading on another forum that by doing the reverse over ride mod it by passes the switch therefore sending a "full 12v" to the coils thus making the coils stronger.Make any sense to you.It went on to say the reason for this is there could be drop in voltage because power is going through other things ie switch,and what not.Any opion,because as you know I have yet to get my rf wheel to work in awd and hope to find a solution before shelling out money I can ill afford
Old Nov 3, 2013 | 07:37 PM
Doesn't increase voltage! Just allows 12 volts constant to the hub coils when in reverse there by over riding the button and "arming" the awd as soon as you place it in reverse. When the situation arises that you need awd in reverse the awd will kick in only if the rear tires slip. If on smooth ground you'll have full speed in reverse same as in forward range. If you have voltage to the rf coil you still may have a mechanical problem and not electrical if the awd doesn't work.
Old Nov 4, 2013 | 11:59 AM
That was my thought also,12v is 12v
bjones12
Jun 16, 2011 04:50 PM
ohiosportsman1
Jul 12, 2008 01:34 PM
shea_davis1214
Mar 28, 2008 11:19 PM
buggyrunner
Dec 10, 2007 10:36 AM
LittleBuddy
Jan 25, 2007 08:51 AM
