2003 Sportsman 700, no spark, post ignition kit upgrade
Old Nov 3, 2013 | 04:39 PM
jhorton's Avatar
Default 2003 Sportsman 700, no spark, post ignition kit upgrade
I installed the upgrade kit, everything hooked up as it should. I have no spark. Any ideas?
Old Nov 3, 2013 | 07:41 PM
Almost all the problems that people had on these kits were grounding issues especially the ground wire at the stator. Just retrace your steps on the wiring and especially the ground wires.Make sure the stator ground is secure under the pick up coil plate.
Old Nov 4, 2013 | 12:27 PM
jhorton's Avatar
Thanks OPT. I'm doing just that and will let you know.
Old Nov 4, 2013 | 02:36 PM
jhorton's Avatar
After taking it all apart and putting it back together 3 times, it is FINALLY running. The problem was a broken wire on the new harness. Frustrating....but fixed. Thankful I don't have to load it up and head back to the Polaris dealer. Thanks!
Old Nov 4, 2013 | 03:22 PM
Dealer would have had the same problem that you've had,but he would have charged you for how long it took him to find that wire short! Glad you found the problem and saved some bucks..
Old Nov 5, 2013 | 03:38 PM
Big600twin's Avatar
The question is do you see a big difference in the performance? I know for me it seemed like it fired immediately as to before, it took a fair amount of cranking before it would start. Also, it seemded to have have a little more pep.
Glad you got it all straightened out.
Old Nov 11, 2013 | 08:24 AM
jhorton's Avatar
With new spark plugs it runs great. Probably better than ever. Saved at least $500 by doing it myself. The local dealer quoted $1000. My wife got online and found this forum and decided it was something I could do myself. The $500+ I saved her can now be used for some new hunting equipment?
Old Nov 11, 2013 | 03:21 PM
If she's like my old lady,she will want half of what you saved since "SHE" found the place to go
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
Thanos
Jul 12, 2015 08:40 PM
jrooker6
Jun 17, 2015 12:28 PM
hot_shoe_cv
Oct 13, 1999 02:16 PM
