2000 sportsman 335 no spark
Old Nov 13, 2013 | 03:41 PM
Bob Kitts's Avatar
Default 2000 sportsman 335 no spark
Howdy first time on the forum. I was reading some posts from back in 08 and got to the point where it will run but wont shut off. There is only 1 black wire in the cdi. Not sure what to do next.
Old Nov 13, 2013 | 04:00 PM
If the black wire is hooked up,you've also eliminated the ignition switch or the emergency switch or it's wiring as a problem,doesn't happen often but the cdi kill circuit wire itself could be shorted out internally not allowing it to kill the ignition. If you don't have a wiring diagram or a service manual here's one for 9 bucks that could help you track down the problem.2000 POLARIS SPORTSMAN 335 4X4 ATV REPAIR MANUAL
Old Nov 13, 2013 | 04:10 PM
Bob Kitts's Avatar
I disconnected the black wire, it goes to aconnector with 2 wires coming out. after disconnecting got spark and starts with just a bump of the switch. does not shut off with the switch on the handlebar or key switch pluged wire back in and it shuts off.
Old Nov 13, 2013 | 04:32 PM
Then either sounds like a wiring short from the harness that the kill wire hooks into or an internal cdi problem.You just need to dig a little deeper if you haven't, especially on the wiring and connectors from the left control switch that go under the pod area.All it takes is a bare wire grounding out the cdi kill wire.
Old Nov 13, 2013 | 04:38 PM
Bob Kitts's Avatar
Thank you sir will be in touch
Jmuddin284
Jan 19, 2026 07:16 AM
coolguy420
Jul 10, 2015 01:17 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
Mikea1978
Jul 4, 2015 12:37 PM
