Rectifier Testing
Old Nov 13, 2013 | 06:30 PM
NewDS650's Avatar
Default Rectifier Testing
Hey guys on my 04 ds650 while at idle voltage across battery shows 14.7-14.8 with little revving doesn't change much. Does this sound like my rectifier is overcharging my battery? Is their a way to test it? Any good replacements or brands to look out for? All help appreciated thanks.
Old Nov 14, 2013 | 09:03 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
14.25 is closer to average but you're not in a range of concern. How far from 12v does it drop while starting? That's more of an area of concern.
Old Dec 2, 2013 | 08:36 PM
papa hogg scoot's Avatar
Loved
Community Favorite
If its regulates at them volts and dont keep climbing then IMO thats fine..
Old Dec 2, 2013 | 08:37 PM
Loved
Community Favorite
So what is atv doing to make you check voltage regulater
Old Dec 4, 2013 | 02:16 PM
PapaWheelie's Avatar
http://forums.atvconnection.com/3100404-post3.html has voltages for a good rectifier. Better qustion might be what is the condition of the battery when you test the voltage. A discharged battery may allow the rectifier to pull higher volts at idle, but i'm not really convinced of that. It's still good to know the condition of the battery. Try using a known fully charged battery when testing the voltage as well. You could bypass the quad battery and run jumper cables to a car battery for the test.
Old Dec 7, 2013 | 10:47 PM
NewDS650's Avatar
I was only checking voltage because I thought my bogging out had something to do with bad spark. It ended up being a running rich condition all set now. It has a new battery too doubt that would be a culprit. Thanks for the help guys.
Joe454
Nov 20, 2020 01:19 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
