front tire clearance
Old Nov 13, 2013 | 08:03 PM
woodsmen3417's Avatar
Default front tire clearance
I wanna run 25x10x12 tires all the way around my 2002 sporty 700 the question is would they clear the front shock assembly with itp ss 212 aftermarket wheels?? Thanks
Old Nov 14, 2013 | 08:51 AM
TLC's Avatar
TLC
Just measure your old tires inside clearance. So if you have 8" wide tires now you only need 1" inside clearance since the other 1" in on the outside where there is nothing for the tire to rub.
So your going to a wider tire in front and a narrower tire in the rear?
Old Nov 14, 2013 | 10:09 AM
I have 25x8-12 fronts and 25x11-12 rear. I've heard rumor that with aftermarket wheels that 9.5 wide tires clears on that model..
Old Nov 14, 2013 | 10:23 AM
TLC's Avatar
TLC
I have the 2001 500 which is the same chassis,tires and suspension as the 2002 700. http://www.atvreviewnetwork.com/enth...e2=3923&go=GoI
I put 25x9 fronts on with room to spare so you should be fine.
Just crank your handle bars from side to side and take measurements to make sure you have the extra 1" inside clearance needed at all turning positions.
Old Nov 14, 2013 | 10:34 AM
The only other thing to watch out for is the setback on the new rims. I don't know what the stock setback is but it is measured from the flat part of the hub to the inside rim. If it's the same on the ITP rims and the stock machine the only other thing to watch out for is the tie rod ends.
Old Nov 14, 2013 | 11:03 AM
It clears the tie rod ends a half inch with the stock wheels and 8" wide tires and the itp wheels is 12x7 and back spacing is 4" ..I know that after markets widen out your stance. and @TLC do you have aftermarkets on your 500 ?
Old Nov 14, 2013 | 11:11 AM
TLC's Avatar
TLC
No I have the stock front rims with the 4 + 3 off set. I think that's the stock front off set.
Here is a good chart to look it up. They also have aftermarket ITP rims in there.
ATV Tire and Wheel Application Chart : ATV Tires Free Shipping : ATV Wheels : Mud-Throwers.com
Old Nov 14, 2013 | 11:18 AM
Oh the 10" should definitely fit with after markets ..what ill do is order two seperate sets of tires and wheels and see if they fit with no problem then ill order the other set if not ill just put 8"
Old Nov 14, 2013 | 11:20 AM
@TLC appreciate the links.
Reactant
Mar 30, 2022 02:08 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
JackTheKing
Jul 14, 2015 09:09 PM
tporath
Jul 11, 2015 12:31 PM
