Testing antifreeze?
Old Dec 3, 2013 | 08:11 PM
WilliamBos's Avatar
Default Testing antifreeze?
Is there a small antifreeze tester for atv's? Took the cap off, antifreeze dropped, could not get enough out for my regular automotive one.
Tested the overflow, but want to test the rad too. Or is the overflow good enough?
Old Dec 3, 2013 | 10:31 PM
Mcdougaldm's Avatar
If you really want to check your rad, just drain a little out. Personally, I would be satisfied with a good reading from the over flow.
Old Dec 4, 2013 | 08:05 AM
Unless you've added water to the overflow bottle,coolant strength will be the same.
Old Dec 5, 2013 | 03:00 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
a car tester works fine by using the over flow as mentioned.
Old Dec 8, 2013 | 08:40 PM
lowflyer's Avatar
They used to sell small testers with little ***** inside. They were the size of a large pen and fit in your top pocket. When 4 ***** would float it was good to -30*
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
Joe454
Nov 20, 2020 01:19 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
