1994 polaris 400l 4x4
Old Dec 5, 2013 | 09:16 PM
raj wheeler's Avatar
Default 1994 polaris 400l 4x4
I replaced the ignition and spark plug tonight and now it's idling crazy high. Any suggestions as to what I may have done wrong. Prior to changing these things I had no idle issues.
Old Dec 6, 2013 | 11:48 PM
Check the simple things first such as carb idle adjustment,cable binding,plus spray contact cleaner around the intake boot and base gasket to check for air leaks. If it idles down you could have an air leak causing the high idle. I still wouldn't over look crank seals that most people forget about. Plus make sure you have the ignition timed properly if you removed the stator plate .Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
