2000 Rancher 350ES clutch install problems
Old Dec 17, 2013 | 11:11 PM
Shodo7272's Avatar
Default 2000 Rancher 350ES clutch install problems
I just installed a clutch kit on my 2000 Rancher 350ES because it was slipping with hard throttle. Now I can't get it to come out of neutral even when I try the manual hand shifter. It was changing gears fine before I installed the clutch kit. Does anyone have any suggestions. Thanks
Old Dec 18, 2013 | 05:51 AM
TLC's Avatar
TLC
You may of fixed you initial problem but now your in the E.S trouble. There are hundreds of post on it if you use this site's search feature.
Most common is the angle sensor, but since yours did work right it probably just a little hook up mistake.
Old Dec 18, 2013 | 05:30 PM
Shodo7272's Avatar
Thanks. I'll look back over everything.
Old Dec 18, 2013 | 08:33 PM
papa hogg scoot's Avatar
Loved
Community Favorite
did you have the auto clutch out also? if so may have the one way bearing backwards
Old Dec 18, 2013 | 08:34 PM
Loved
Community Favorite
You could have also have the shift linkage off one spline...this will may shift pattern different
Old Dec 19, 2013 | 12:42 AM
Shodo7272's Avatar
Yes I did. It's very possible I have that oneway bearing backwards. Thanks I will check that.
Old Dec 19, 2013 | 12:46 AM
Shodo7272's Avatar
I believe the shift linkage on this model has a master spline but I will double check. I'm gonna break it back down in the morning. I will report back on it. I really believe I could have put the one way bearing in backwards. Thanks for your knowledge.
WilliamBos
Sep 30, 2015 08:08 AM
Land_shark1
Jul 10, 2015 12:53 AM
ROWALKER
Jun 15, 2015 05:38 PM
wbfjim
Jun 8, 2015 06:20 PM
