polaris hawkeye rear camber
Old Dec 29, 2013 | 07:46 PM
sportsman09's Avatar
Default polaris hawkeye rear camber
is there a way to adjust the camber on these? the rear tires are tilting out on the top real bad in my opinion. going to replace all bushings as there is some play in them. just would like the wheels to look better then looking like a v in the back. doesn't seem to change much with weight on the machine either. I had a 09 sportsman 400 with the same chassis but didn't notice this problem on that one.
Old Dec 29, 2013 | 08:16 PM
You can ramp up the rear spring adjuster and see if it helps. If it doesn't you can call Epi or your dealer and see if they have any heavier springs available if adjusting the spring tension and bushings don't help. Can't adjust the camber,plus has a different rear shock than your 400 had.EPI Performance ATV and Snowmobile Clutch Kits: Suspension Springs
Old Dec 29, 2013 | 10:51 PM
If I would crank up the shocks it would look worse. It's like the rear needs to be loaded down just to get it to look right. Maybe this is just the design. To me if it had shorter upper arm bracket to bring the top in it would help.
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
rcappie4
Jul 10, 2015 04:54 PM
cornermike
Jul 8, 2015 11:44 PM
Rider252
Jul 6, 2015 03:37 PM
