Sportsman Camshaft
Old Jan 4, 2014 | 11:00 PM
Redneck306's Avatar
Default Sportsman Camshaft
Hi,
I started a previous forum asking about what was the problem with my wheeler... I think that you all have helped me figure it out but I have a question specifically about the cam shaft. Mine is a 1998 Polaris sportsman 500 the Polaris OEM part number is 3084898 replaced by 3086212, I saw where people said to make sure I replace with it with the HO one which is what Polaris started using with the 2001 Polaris... but the part number for a 2001 Polaris sportsman 500 camshaft is 3085855, I am so confused because I do not want to spend 2-3 hundred for the wrong part.
Old Jan 4, 2014 | 11:57 PM
Redneck306's Avatar
I do see where others talked about replacing the 1998 carb that is 32mm with the 2001 carb that is 40mm which I am willing to do but the person said that I would have to get new boots for it as it will be bigger than the boots I have but I can not find them on ebay or the Polaris parts catalog website... I cant find parts numbers and in the search I typed in 2001 Polaris sportsman 500 ho carb boots and nothing comes up... any advice on this?
Old Jan 5, 2014 | 01:43 AM
TLC's Avatar
TLC
Just get the H.O cam and keep your 36mm carb . To move to a 40mm yes you will have to change the rubber boots.
I,m not sure its worth the bother.
Old Jan 5, 2014 | 07:32 AM
Redneck306's Avatar
Any idea on what the rubber boots are called or where to get them I can't find them.on eBay
Old Jan 5, 2014 | 08:51 AM
You'd have to order the larger intake manifold plus the carb. Just get the HO cam if you wish and keep your same carb as suggested by TLC!!!. Item #38.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Jan 5, 2014 | 08:59 AM
Redneck306's Avatar
I figured I would get the HO cam but I found the carb and I think the new tube from the air box to the carb but I am having trouble finding the intake manifold...
these are the urls I found are
Complete Carburetor Assembly 2001 2002 2003 2004 Polaris Sportsman 500 HO | eBay
tube from the air box to the carb- Polaris New ATV Carb Carburetor Boot 40mm Sportsman | eBay
but nothing for the correct intake manifold
Old Jan 5, 2014 | 09:08 AM
You sure are making it hard on yourself! I listed the intake manifold above that you would need! Item #38.
Old Jan 5, 2014 | 09:11 AM
Redneck306's Avatar
oh okay, my bad... idk why I did not see that... not to keep on being a pain in the but was the pipe from the air box to the carburetor right?
Old Jan 5, 2014 | 09:27 AM
NO! Your air box and at least a 2001 air box are different along with the boot from the carb to the air box. Your model air box and tube.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
2001 air box and tube(tube size need to fit the rear of the 40 mm carb). Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
You would have to rig this tube up to fit your box,change out the whole air box on yours or do as some and run just a clamp on filter! All this trouble and extra cost in my opinion isn't worth it!
Jmuddin284
Jan 19, 2026 07:16 AM
Cole Hadden
Jun 15, 2025 09:05 AM
Polarisman1123
Aug 3, 2015 02:08 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
