Dishing wheels out to be wider?
Old Mar 29, 2001 | 10:19 AM
Aaron10's Avatar
I turned my stock wheels on my 400ex around and dished the front about 4 or so inches wider. I took the valve stems and turned them inside out and put them back in as a dummy plug. Then drilled a whole on the other side and put new valve stems in and made the front ALOT wider. I heard this is bad for your bearings or something. But when you buy aftermarket wheels you buy them dished out like that, so why can't you do your stock ones that way? Any info, please let me know.
Old Mar 29, 2001 | 10:35 AM
DSAPP's Avatar
I did that to my girlfriends 250EX
but the steel lug nut inserts had to be reversed also, and they're conical shaped so I had to use 2 different sized washers to help spread the contact force on the aluminum holes
did you have to do this on the 400? do they have steel inserts?
Old Mar 29, 2001 | 12:00 PM
ModdedX's Avatar
We used to do that a long time ago on our 4wheelers. We never had a problem with the bearings!!
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
