Polaris Electrical Problems
Old Jan 22, 2014 | 10:57 PM
jntauto's Avatar
Default Polaris Electrical Problems
95 Polaris explorer 400, I recently built up basicly and runs fine one day, the next it either doesn't or will not start cold, once ran and warm it will fire right up, also recently while riding it wants to die, I mess with headlight switch flipping it back and forth from off to low to high then back to off and it seems to help, why would headlight switch make a difference? I took off entire switch cleaned and wired up kill switch direct thinking it would help but didn't....please help
Old Jan 23, 2014 | 10:22 AM
Could be electrical or mechanical such as compression causing problems. Best if you have a manual for trouble shooting as it show all electrical checks to eliminate problem areas. Could be as simple as the cdi black kill wire shorting out or even the reverse limiter module. Manual shows the electrical tests along with mechanical tests.Index of /ORV Manuals/Polaris/1985-1995 - All Models
ripperray
Oct 10, 2023 02:42 AM
green giant
Jul 13, 2017 12:07 PM
txkevin
Sep 21, 2015 02:02 PM
DOAinNY
Jun 11, 2015 10:34 PM
TJM
Jun 11, 2015 01:28 PM
