2004 Polaris SPortsman 600 Twin stock rims - New Tire Question
Old Feb 10, 2014 | 09:43 AM
Bruiser613's Avatar
Default 2004 Polaris SPortsman 600 Twin stock rims - New Tire Question
Hi I currently have a 2004 Polaris Sportsman 600 twin with stock rims and Carlisle tires. The Front tires are 25x8-12 and the rear tires are 25x11-12.
I was going to buy some new tires. I was wondering if anyone would know if the following tires could be installed on my stock rims?
ITP XL 26” – Front 26x10-12 and Rear 26x12-12
Or
ITP XL 25” – Front 25x8-12 and Rear 25x12-12
I'm just wondering if I would need new rims as well if I purchased either the ITP Mud Lite 25" or 26" tires.
Many thanks!
Old Feb 11, 2014 | 08:31 AM
TLC's Avatar
TLC
You do not need rims to change tire size as long as the tires are for your 12" rims.
A 2004 should not have those odd ball 10" rear rims.
I would just measure your fronts if your going 10" wide fronts to make sure nothing rubs.
I know 9" wide fronts are fine.
You can go as wide as you want on the rears.
My little 350 took 26x9 fronts and 26x11 rears with room to spare, and Zillas have a taller 1.19" lug then XL's.
Old Feb 11, 2014 | 08:35 AM
Bruiser613's Avatar
I just measure your fronts if you going 10" wide fronts to make sure nothing rubs. I know 9" wide fronts are fine.
Thanks for the reply. My existing 8" front tire sits close to the shock so I think I will stick with the 25"x8" front tire and 25"x12" on the back.
Old Feb 11, 2014 | 09:49 AM
TLC's Avatar
TLC
Remember when you go a inch wider on the fronts your only going 1/2" wider towards your shock since the other 1/2" in towards the outside.
26" are a nice look on a ATV, are you sure 9" wide fronts would rub? I don,t think 26" come in 8" widths on the XLs.
Old Feb 11, 2014 | 09:59 AM
Bruiser613's Avatar
I think 9" would fit but the problem is the 26" ITP mud lite XL only come in 26x10-12 in the front and I don't think the 10" would fit.
The 25" ITP mud lite XL offer the 25x8-12 for the front.
I would have to go with the ITP mud lite XTR if I wanted the 26x9-12 front tire but the XTR cost alot more than the XL.
Old Feb 11, 2014 | 02:36 PM
Bruiser613's Avatar
The place I found has good prices but just don't offer the ITP Mud Lite XL 26x9-12
Old Feb 14, 2014 | 08:30 PM
woodsmen3417's Avatar
On stock rim highest can fit is 9" you need 1"spacer to fit 10" and aftermarket wheels highest you can fit is 10.5"
Old Feb 15, 2014 | 10:39 PM
Bruiser613's Avatar
Yah the rim seems to be able to accomodate a 9" wheel but it looks like it would rub on the shock assembly.
I think I'll play it safe and go with the same 25x8-12 on the front but go from 25x11-12 to 25x12-12 on the back.
neilbedwell
Nov 10, 2018 11:02 AM
kbbgood
Utility ATVs
24
Mar 9, 2016 03:08 PM
gfl0224
Jun 27, 2015 06:52 PM
yellowpolaris
Jun 21, 2015 11:13 AM
May 27, 2015 11:15 AM
