Anyone have a swingarm work loose on a scrambler?
Old Mar 30, 2001 | 10:13 AM
lancems007's Avatar
My left side is loose. What should I do to keep it from happening again?
Old Mar 31, 2001 | 02:55 PM
Farmr123's Avatar
If it is loose because the bolt worked loose, you MUST replace the lock-nut, preferably with an all-steel lock-nut, not the nylok type. Replace the washer under the bolt head with a new one, and be sure to bend the ears over the flats of the bolt. If the hole in the frame is wobbled oval, a new one should be welded in. If it is just barely loose, it may hold. This is true with any of the pre-concentric drive units with chain drive. For the concentric drive units, I haven't seen one loose yet so wouldn't know what to suggest.
Reactant
Mar 30, 2022 02:08 AM
hugemoth
Jul 20, 2020 03:28 AM
Albertascramblerx
Jul 8, 2015 11:56 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
