yamaha breeze 125 ignition problem
Old May 30, 2014 | 10:02 PM
dlow8's Avatar
Default yamaha breeze 125 ignition problem
Hello everyone. I have a yamaha breeze I picked up.... I have a freshly charged battery, but I don't have any power when the key is turned. No head lights or neutral led...... The quad is an automatic, and has a side shifter on it. If I put the quad in reverse. The reverse led light illuminates...... I have checked the fuse above the rear tire and it was fine. I have a tester, I just need some direction as to what/where I need to start checking things...... One last thing. The quad has sat up for a few years... I have already pulled the carb and cleaned jets, cleaned gas tank etc.....
Old May 31, 2014 | 06:05 AM
Jaster94's Avatar
check in and around the solenoid and the backside of the ignition to make sure your wires are terminated, sounds like you already checked the inline fuse.
Old May 31, 2014 | 07:43 AM
dlow8's Avatar
Thanks jaster94, I will check when I get home, If I recall the solenoid is mounted on the frame under the seat... Will double check it
Old Jun 2, 2014 | 06:37 AM
dlow8's Avatar
Default Solved
Turns out the blue wire that runs down the frame was cut. I got er fixed up.
Old Jun 3, 2014 | 06:21 AM
Jaster94's Avatar
good deal! glad you got'er going.
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
Ragtop
Jun 27, 2015 03:04 AM
wildbill59
Jun 9, 2015 02:28 AM
cornermike
May 28, 2015 09:47 AM
Rod
Oct 4, 1999 12:37 PM
