bypass safety switches
Old Jun 16, 2014 | 06:09 PM
bamax100's Avatar
Default bypass safety switches
I have a fuxin 110cc. I can get it to turn over rather easily.new plug,carb rebuilt etc etc.
it has the brake master cylinder on each handle for the brakes with the brake safety switches. and I have the pull cord kill switch on the rear.
can I just unplug the rear kill switch an it will be fine?
and on the handle bar brake switch,if I take off the wires,do I leave them open or a jumper wire to make the cdi box read it to start. I think this is my problem with it not starting.
thanks
Old Jun 16, 2014 | 06:22 PM
bamax100's Avatar
took the remote kill switch box off and it rattled like rocks were inside.can I just unplug it?
and I do not see a cdi box nor a connector for one.is the remote kill box the cdi also?
Old Jun 17, 2014 | 08:57 AM
Zrock's Avatar
Super Quad Patrol
run a test meter across the leads to both switches and test.. find out if they are normal open or closed. If they are open then just unplug if closed need jumper..
Old Jun 17, 2014 | 09:01 AM
bamax100's Avatar
I put my meter on them and got nothing.I turned the atv over trying to start and got nothing again. I am still looking for wires where someone may have cut the cdi box off this thing.
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
nick c
Sep 13, 2015 10:08 AM
Jason An Stacy Jones
Utility ATVs
Sep 6, 2015 02:25 AM
toonces
Sep 5, 2015 01:14 PM
