1999 Yamaha big bear 350 fire problems
Old Jul 24, 2014 | 08:39 PM
bfcostl's Avatar
Default 1999 Yamaha big bear 350 fire problems
My big bear was starting fine rebuilt top end now will not fire when I jump solenoid nor will it turn over lights work switch works just won't turn over or fire really stumped new stator new starter new solenoid key switch new please can anybody help
Old Jul 25, 2014 | 02:25 AM
Can you turn the engine over by hand? If so check the earths and the main wires from battery to solenoid to starter.
Old Jul 25, 2014 | 05:54 AM
bfcostl's Avatar
I can turn it over by hand I can jump the solenoid and get it to turn over just no fire and won't turn over by pushing button there's a blue and white wire running along the frame in the harness that's hot when I push button it turns to a ground
Old Jul 25, 2014 | 09:28 PM
bfcostl's Avatar
Default 1999 big bear 350 wiring problems
Please help can someone tell me why it won't turn over or fire turns over when I jump the solenoid but still no fire
Old Jul 25, 2014 | 10:38 PM
If you have an ignition problem to begin with,just jumping the solenoid only allows the starter to turn the engine over. You can pull the plug cap off and check if you have spark with the bare wire against the engine when you jump the solenoid. If you do the resistor in the plug cap has blown. If no spark I'd trace where that blue/white wire you mentioned goes to and see if you accidentally unplugged the coil wire,etc. Not sure on Yamaha,but blue/white was the color for the coil wire on several Polaris year models. If none of this helps might be best to invest in a good manual that has the wiring schematic, trouble shooting guides on the ignition system,along with resistance specs for the stator and coil.Hopefully it's something simple if it worked fine before you did the top end.
Old Jul 25, 2014 | 11:12 PM
bfcostl's Avatar
The blue and white goes from neutral light to solenoid no volts going to orange wire on coil there's a black with white stripe coming from handlebar switch to cdi
Old Jul 26, 2014 | 02:50 AM
Not sure if the 1999 had a solenoid with a fuse attached, the later ones have, you can fit these the wrong way round. The binding posts for the thick wires are marked B for battery and M for motor. Double check those earths, on a Yam, they can look OK but not work.
Old Jul 26, 2014 | 05:02 PM
bfcostl's Avatar
Well an update apparently if cdi is bad it will not do anything had a bad cdi and the handlebar switch was bad it was just crazy that both went out at the same time
Yamaha_
Utility ATVs
Dec 16, 2022 07:49 PM
volsgo30
Jun 4, 2015 06:07 PM
finbone
Aug 29, 2000 04:46 PM
clayman
Jan 25, 2000 05:57 PM
Glenn McDonald
Aug 26, 1999 12:46 AM
