reverse light
Old Apr 1, 2001 | 09:19 PM
tmbk2's Avatar
What is the best set up for installing a reverse light on a sp 500?
Old Apr 2, 2001 | 07:31 AM
Loyal's Avatar
I spliced mine into the reverse light in the pod and bolted the light under the back rack. When you shift into reverse . . . voila instant light.
Old Apr 2, 2001 | 07:03 PM
YamaHonda's Avatar
I added a reverse light to my Sportsman HO using a relay switch that is triggered when you shift to reverse. You can get the relay at an autostore where they sell driving lights, etc. I ran a power wire from the battery to the relay, then ran a ground wire from the relay to the frame. Then I tapped into the PURPLE wire in the headlight pod to trigger the relay. I zip-tied the relay to the handlebars inside the headlight pod - this keeps water, mud, etc away. You then have to run a wire from the relay to the light and then run another ground wire from the light to the frame. This sounds a lot more complicated than it is but using a relay switch will provide power straight from the battery rather than drawing power from the reverse circuit.
Old Apr 4, 2001 | 03:28 AM
derrick12's Avatar
i agree with this method, except make sure you fuse the circuit going to the light, a short could be the end of the road for your electrical system
SyTye
Sep 11, 2015 02:45 PM
Pahuntman
Sep 5, 2015 11:07 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Derek Allen
Jul 22, 2015 09:25 PM
