Magnum 500 broken axles!
Old Apr 2, 2001 | 01:23 AM
joecool's Avatar
I have a 2000 mag 500. it isn't quite a year old and i love it!
except i have broken 2 rear axles!!
one was last fall after i put about 1100 miles on it. the second was yesterday and their was only about 200 miles on the axle!
has anybody had this happen?
i live in northern b.c. canada
there is some awesome riding here!!
my buddie ride the other brands and i sure got a ribbing the second time it broke
well if anyone has had this happen let me know
also has anyone tried aftermarket axles?
what is recomended?
joe
Old Apr 2, 2001 | 01:49 AM
Dazed's Avatar
Mnexplorers buddy also has broke two axels which side have you broke?
Old Apr 2, 2001 | 02:09 AM
joecool's Avatar
it was the very outside right
right at the start of the splines in the wheel hub!
the left side has a tubue all the way to the hub but the right is exposed from the rearend to the hub!
Old Apr 2, 2001 | 02:14 AM
Dazed's Avatar
Yep same side and i have it on video MNXPLORER took the video did you put it on the side or crash hard?
Old Apr 2, 2001 | 02:18 AM
joecool's Avatar
the second time i have no idea why!!
the first i hit a ditch at about 35 mph which just about threw me over forward!
i have jumped my bike but so has everyone i know!
Old Apr 2, 2001 | 03:55 AM
DaveC's Avatar
what size tires do you have on it?
Old Apr 2, 2001 | 05:59 PM
joecool's Avatar
25x12.5x10 bearclaws!
they are the same height as stock.
it looks as if the axle twisted slightly before it broke!
Old Apr 2, 2001 | 06:42 PM
LEP7MM's Avatar
MNXPLORER's buddy was one of our trial guides on the ride yesterday. He had a loner SP500 instead. I had heard that the axle breakage was due to the design of the splined area and that there was no chamfer down to the end by the splines causing a week spot that has been prone to breakage. Haven't looked at one of the axles to see for sure. I think Dura Blue may have an aftermarket axle that would be a lot stronger.
Old Apr 2, 2001 | 11:56 PM
425Xpedition's Avatar
The axle breakage is a common thing down here. One thing that we have found to help is to torque the hubs to 100 ft lbs and check them frequently. Durablue does make a rear axle for the shaft drive bikes. It is stronger but it breaks on the left side. When it breaks it screws up the disk, caliper and axle tube. I have broken two Durablue axles and there lifetime warranty is a joke. Everybody that I know that had a Durablue broke it and replaced it with a stock axle.
Old Apr 4, 2001 | 10:44 PM
mudmachine's Avatar
My 99 Model broke two axles and bent the third one...
First one was with 4 months on the bike, second one was with a year on the bike, and the bend was due to a wreck.
First time was running 27" Blackwater XT's, second time was Tri-Claw Magnums.... both times it broke, it busted just as others have said... Right side where the hub splines end. It s a common problem, and it is a manufacturing defect. The down side is that there are no replacements that are any better. I don't have personal experience with Dura Blue on the Magnum, but I fought with them on an axle on a Warrior, 300EX, and Blaster....
As others have said, tighten the hub nuts "TIGHT!!
Godd Luck
