Check piston on 86 Yamaha moto4
Just got an 86 Yamaha 225 Moto4 for $100. Seller said it ran when they last used it 10 years ago. I put a new battery in it and the lights work and neutral light works. It seems to shift fine. However I think the piston is seized up from rust.
What is my best option? I put some oil in the spark plug hole to let it soak a little while ago. Can I remove the top end without taking the entire engine out?
You can almost always get the head and cylinder off with the engine in the frame but you won't get the cylinder off if it is stuck to the piston. I would try taking the pull start off and rocking the crank gently backwards and forwards with a bar. Diesel fuel or easing oil down the plug hole is recommended by mechanics. Leaving for a couple of days to soak before freeing off is a good idea. If it is still stuck, take the head off and knock the piston down the bore with a block of wood as a drift.
I have the same quad.
Regarding its former carb problems: https://atvconnection.com/forums/yam...00-carb-2.html
toonces
Oct 16, 2019 12:11 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Mojave250A
Jul 11, 2015 10:38 AM
