Carb Issues Yamaha Wolverine 450.
Old Nov 2, 2014 | 02:24 PM
wildfan97's Avatar
Default Carb Issues Yamaha Wolverine 450.
Hi, i'm newer to Atving and one of my 07 wolverines 450 has not been running right. It sputters and does not go over a couple mph. Putting the choke on helps a little bit, but not much. I cleaned the gas tank, and found a little bit of sand, then cleaned the carb. It then runs fine for a little bit, but then when i give it a decent amount of gas, it sputters and wont run right again. I cleaned the carb and installed a fuel filter, and the same thing happened. Cleaned it one more time, and same issue happened. I am not sure what to do now. Should i Rebuild the carb? Any help would be greatly appreciated. Thanks.
Old Nov 2, 2014 | 02:55 PM
If you can't find an obvious air leak such as the intake manifold,I'd install a carb kit.As many as I've had to do I'd never pull a carb and just clean one.A lot of times you end up just having to go back in. Frustrating when you do. Always install a new kit and eliminate the carb as a problem. Blow out all the passages in the carb,fuel line to make sure you have all the sand out. Check the float height,plus not a bad idea to check valve clearance while you're at it. http://www.ebay.com/itm/YAMAHA-2007-2010-YFM450FX-Wolverine-Carburetor-Repair-Kit-YFM-450-Carb-Kit-/231288508019?pt=Motors_ATV_Parts_Accessories&hash=item35d9de8e73&vxp=mtr
JBibb
Jul 4, 2015 10:16 AM
holmbergm97
May 27, 2015 07:23 AM
MoJave88
Mar 6, 2001 05:39 PM
ATV_MAN
Dec 12, 2000 05:55 PM
swire
Oct 30, 2000 03:25 AM
