1988 yamaha 350 big bear need parts
Old Nov 17, 2014 | 10:28 PM
Bernhard's Avatar
Bernhard Schmidt
Default 1988 yamaha 350 big bear need parts
I have a 1988 yamaha 350 Big Bear 4x4 its a pretty reliable machine but a couple months ago one wheel stopped spinning i found out later it was the part that hold the wheel it spins with the axle but the teeth that make the wheel spin were chewed up and i have absolutly no idea where i can get the part other than kijiji or ebay please help woul a YAMAHA Dealer have them?
Old Nov 18, 2014 | 03:20 AM
Assuming you are referring to the rear hub and axle, any Yamaha dealer will have the parts, but if the splines on the axle shaft are shot and you need a new axle you are in for a big bill. The rear hubs are not very expensive.
Honda 300s were prone to this and, instead of new parts, we used to run a bead of weld round the joint where hub and axle meet, not on the nut side. Aftermarket suppliers started making shafts and hubs cheap for the Honda so we now fit these instead. They don't make them for Yams though as Yamaha kept changing the rear axle so there aren't enough of each type to make pattern parts worthwhile.
Old Nov 18, 2014 | 07:24 AM
Bernhard's Avatar
Bernhard Schmidt
Default Yamaha owner
Thankyoy so much the teeth on the axle are still good i jest need the hub thanks once again
Old Nov 18, 2014 | 07:57 AM
TLC's Avatar
TLC
The hubs are not much and easy to change. Part number 6 or 1 depending on which side. $68.89 from this place. Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse they call it a COLLAR,WHEEL. Part# 2HR-25383-01-00
lightninboy
May 16, 2021 09:52 PM
toonces
Oct 16, 2019 12:11 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Elad Cohen
Arctic Cat Side By Sides
Jul 4, 2015 02:26 AM
