Warrior 350 intermittant starting
Old Nov 24, 2014 | 10:24 AM
jimgodfrey's Avatar
Default Warrior 350 intermittant starting
My 350 Warrior sometimes wants to just click when I hit the starter. It will start if pulled and if I put it in gear and rock it it will start as well.
I have checked the battery connections.
Old Nov 25, 2014 | 03:32 AM
Your starter brushes are probably ready for replacement. Get a test bulb and connect it between the starter live terminal and earth. If the bulb lights and the motor doesn't turn when you press the starter button you have a bad starter, either a new starter, or probably just brushes, will cure it. If the bulb doesn't light but the solenoid clicks, you have a bad solenoid.
tiresharkdbb
Sep 3, 2017 02:06 AM
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
